Hi all looking for suggestions on speaker cable for naim nova and bowers 805 D3 and is it worth replacing original bowers links .
Many thanks
Yes do remove those nasty links
What speaker cables you are using right now and what is it that you didn’t like about the sound.
@Clive1 I have the older B&W 805N, I have always used Cord cable Oydessey, been really happy with the cable for 16 years no I see no reason to change, I have my speakers bi wired so removed the links
Just recently, I’ve made the change to Chord Epic Twin, this one is going to stay in my system for a long time …
If you use a Naim power amp, I would expect it to be happier without the biwire cables.
I used to own the Chord Epic Twin. It’s a great cable and value for money sound for pound. I find it to be better balanced and more refined than the NACA5.
