I can’t visualise where the LP goes (or indeed whether it comes out in the same shape as it went in).
I’ve never used a record cleaner. I replace the inner sleeves of all my LPs when I first get them with high quality Mobile Fidelity or similar sleeve, and I clean the stylus before playing each LP.
Hi @Toon
Great purchase. I’d absolutely love one!!
Get on the current Degritter thread - we’d love to hear your views and experiences of your new fancy RCM.
All my records were cleaned and once done stored in Nagaoka anti static inner sleeves.
Not only did this stop the static and the slip mat stay on the LP12, but there were no snaps, crackles or pops, plus there was dead silance in between the tracks.
Hi there. I find the simple Project RCM works perfectly. Makes a real difference to background noise and static. I use the “Art du Son” fluid.
May have to experiment with upgraded mains leads and bespoke support though!!
