Hi guys,
Can I connect a record player to Mu-so 2nd generation?
Yes you can - connect via analogue input (as long as you use a phono stage or the turntable has a built-in phono stage)
Qb also an option!
Hi I bought the turntable you pointed out to me, it’s really very nice. I would like to know one thing, when I turn on the turntable (without playing it, only on) and put the Mu-so on “analog” I hear a slight hum in the background, especially if I turn up the volume. It’s normal?
Yes
