I am planning to buy a new cartridge Rega Exact with my current phono Stageline N, my system detail as below, please kindly comment on it, is it match ? How is the combo presentation ?
Pro-ject Xtension 9 with 9cc Evolution Tonearm
282/Dual Hi-Cap DR/250.2
Kudos Super 10
I have a new Rega Exact on an RP6 connected to a StageLine N and NAC252/SCDR/NAP250DR. It sounds great.
The same cartridge, TT and StageLine connected to a NAC282/HCDR/250.2 also sounds fine.
On a recapped NAC42 with MM boards (might not have been recapped, but I don’t know), vocals sounded a bit recessed. Otherwise it was fine.
I am slowly returning to vinyl by cleaning my old LPs and buying replacements for the ones that have been lost over the years. I am looking for a better TT as a project for this year, but I am no hurry and enjoying my middle-level Rega. If and when it is replaced, it will be relegated to the second system with the 282.
In terms of bass and dynamics, I am very happy with them for the music I listen to, including pop/rock, but I do not listen to symphonic music, opera, punk or heavy metal at loud volume levels (but certainly at moderate levels).
My speakers (Spendor stand mounts up to size 1/2) are not bass monsters and tend to have a reputation for neutral rendition without any fatigue.
For the price, the StageLine N and Rega Exact are a great combination for my ears with my speakers and in my room. However, I do expect to see an improvement if I can upgrade my sources later this year. Although I mostly stream from my NAS and Tidal, I am still buying and listening to more and more vinyl again, so that upgrade is just a matter of time.
Used StageLines are not expensive, so if you try one and it does not suit you, you can probably move it on with little or no loss.
