Rega phono stage connection to 282
Hi
I’m new to this forum & am looking for some advice.I currently have a naim nac 282/250dr set up. My issue is I want to connect my rega phono stage to the 282 5pin din connection.
I realize I need a 5pin din to rca but which is the best connection to use on the back,tuner aux, etc.
I currently use rca for both cd & phono stage but wish to change the phono configuration for better grounding……Also any advice on which chord interconnect would suite this method.
I have my Rega Aria phono going into NAC282 Aux2. Either Aux1 or Aux2 should be fine here.
RCA into DIN is maybe best.
HiLine if you can get one, lots around pre-loved.
Otherwise, suggest Chord Shawline…
Here’s a useful read, if you are interested
Good luck
R
Naim makes a very good RCA to Din interconnect. I used one when I had a Rega P10 and it was excellent. Note that you are looking for RCA to Din, not Din to RCA. The two are wired differently.
Thanks for the answers. According to research I need a rca to din interconnect.
directional rca to din as the signal is from the ARIA to the 282 & not din to rca.
I just needed clarification on that but also which din socket would be the best to use.Cd,tuner aux2
also apologies its an AOS not an aria.
I’m not sure why, as I explained that you needed RCA to Din in my reply to you. I can say it again if you wish. You need RCA to Din.
All the sockets are in theory the same, so you can just try each and see if you hear a difference.
AUX2 is the typical input for phono. It’s also what the RCA input maps to. I use the RCA input for my phono-stage, but that’s because I use balanced (XLR) cables with RCA pigtail adapters on the end that goes into my 252.
If you run a Naim phonostage.
If I recall AUX2 power up the Naim stage.
I’d use another input.
AUX2 can be either a powered or unpowered (RCA Phono or DIN) input
Hi HH
Where do you buy the naim RCA to DIN. Do you have to go into a dealer?
Peter
AUX2 has both powered and unpowered inputs. When I had a Superline I ran it into the powered AUX2. Later I got a SCDR and then ran it into the unpowered AUX2. Now I have a non-Naim phono-stage, and remapped the AUX2 DIN input to the RCA input, which is what I use now.
AUX2 is a typical input for phono-stages. Of course one can use the other DIN inputs, but personally I would stick to those that leave ch1/ch2-out open (i.e. aux2, tuner, CD).
You need to ask a Naim dealer to order you one. I expect they would post it to you if you didn’t want to travel for such a small item.
Does the DIN plug change anything with RCAs on the other end?
Thanks for the advice guys.
My rega planar 10 /Cyrus phono sig was my original set up via remapped rca. The reason for my original query was due to upgrading to a rega Aos phono stage. I then was looking at using rca to din for better grounding as the planar only does so via the left channel rca….Obviously,as I’d never previously used din connections on my other source my cd player (Cyrus cdi xr + pad xr) I was looking for the best option to achieve this.
Hope this makes sense
Unless you are trying to solve a grounding/hum problem I question you’d even notice the difference.
I have a fully balanced phono-stage. AV Options made me a XLR/DIN Y-cable for connecting my 252. Since then I upgraded to Siltech balanced cables and use pigtail female XLR/male RCA adapters for my 252, for the RCA phono input on my 252. That works great, and I no longer use the AV Options XLR/DIN cable.
Yes, there’s still a small advantage even with just one DIN.
Thanks everyone on here for your input. Problem solved. I have ordered a chord shawlineX rca-din. This will connect my rega Aos via AV2 din. I have remapped the rca av2 (deselected).
As mc cartridges are the lowest input I want to cut down any background hiss or hum and achieve better grounding. Using this method I should merge the left &right (Rega’s method) ground return into a single shared negative (+ve)to mirror naims star grounding…..no loops.
All about continuity .
Again cheers guys.
