Hi everyone, my first post here as a happy and new Naim Uniti Nova owner
Was wondering about the remote, does anyone know how to get it to light up when you pick it up? I’ve tried to enable this option in the Naim app, without any effect though. Any suggestions/ideas on how to fix this?
Ok, it’s not a function that you can turn on or off so if the remote is working ok otherwise I’d say it’s faulty, maybe remove batteries and reinsert and see if it resets
The lighting up when picking up can be turned off, it’s in the app > Settings > Other Settings > Remote > Motion detect. (What you can’t turn on or off, I think, is the lighting up when pressing a button.) However, @GijsK wrote that he tried enabling the option in the app, so I guess something is wrong
My streamer remote was far too sensitive and ate batteries for a pastime. Somehow I managed to reduce the sensitivity so that I now have to really shake to get it to light up. Unfortunately I cannot remember how I achieved this! It may have been through the options on the screen of the unit in addition to the options available through the app.
I don’t think there are any options for sensitivity but happy to be corrected. I had a Nova for a short time and the remote was super sensitive with this one, so much that I mistakenly thought it had a proximity sensor. Then with the NDX2 it changed and I have to actually pick it up
