I have removed Serviio from my main computer however it is still on my Naim app upnp page. Anyone know how to remove it from the Naim app? Thanks.
You can use the Reset App option under “other settings” in the Naim app, under the gearwheel settings icon. That should do it.
Or delete the Naim app and reinstall it would do it too.
Best
