Hi. I came downstairs this morning to find our wifi had some issues. Rebooting the Virgin Media Hub 3 has solved everything, except for my 1st Generation MuSo which no longer connects to my BT Whole Home mesh network. So, I’m just seeing the purple flashing light on the side. I’ve tried rebooting the MuSo, and also tried a reset with a pin into the reset hole, both without success.
The Naim app is no good as it can’t find the MuSo as it isn’t connected.
I wondered if anyone had any more ideas?
Really frustrating, it was fine last night!!
Mike
