Hi all. After some weeks of fiddling with speaker positioning and swapping round isolation kit and cables to try and reduce a slightly bright sound, I tried resetting the SN2. I’m currently listening to results (first indications seem positive but I’ve only just done the reset) but it did raise a few questions that a quick search didn’t answer…
Under what circumstances should resetting be done?
What does resetting aim to cure?
What is actually going on inside the amp when the process takes place?
Cheers.
It is possible to restore all the programmable settings to factory defaults, using the remote handset. There won’t be an impact on the sound, just the way it operates.
The how to do it is all in the manual.
7.7: To restore all Supernait 2 programmable settings to the
factory defaults press and hold the remote handset disp
key while the unit is in program mode. The Supernait 2 will
exit from program mode following this operation.
Hungryhalibut’s reply above explains, it just resets the programmable options to factory defaults. Under most circumstances there’s no reason to do it, if you have an amp where somehow the logic has got confused, this’ll get back to the starting position, but it’s not something I’d expect anyone to need to do unless they’re taking ownership of a preloaded item and want to set it up from new.
