Return of the graphic equaliser?
I am 69 and away on holiday. I forgot my hearing aids and everything, music included, sounds flat. Like many people of my age (and younger) I suffer from high frequency hearing loss. When I have my hearing aids the issue not a bar to me enjoying music through quality systems like Naim. For reasons I fully understand the old bass and treble adjusters on amps disappeared years ago. Perhaps it was the law of unforeseen consequences - not being able to adjust the frequency presentation meant that listeners heard what music producers intended but left listeners disadvantaged by hearing loss worse off. Any ideas on addressing this problem? Are any devices available to boost high frequencies from amps?
Popular belief among audiophiles is that tone controls adversely affect sound quality, but as I have written here on several occasions I am increasingly questioning this philosophy. Conventional tone controls may adversely affect sound quality by their very presence in the signal path even when set ‘flat’, which is where the notion originated 50 years ago, and dsp is said to possibly produce artefacts. But to view this dispassionately, if the tone controls/dsp correct inaccuracies in the sound spectrum, whether system (should not be in a perfect system - but what systems are perfect?) or room induced, or compensate for deficiencies in the listener’s hearing, or correct for reduced hearing spectral sensitivity when playing at low sound levels, then surely it is simply a question of which effect is worse: the adverse effect on sound quality caused by the tone controls/dsp themselves, or the limitations they are being used to correct? And I suspect that in most cases the adverse effect of the controls/dsp themselves will be orders of magnitude less significant than the benefits they bring,
That said, great caution is needed if boosting as for every 3dB increase in loudness the amp power to the speaker is doubled. This means that to compensate for a hearing loss deficiency of say 15dB, which is quite mild, would increase power by a factor of 32, so 1W becomes 32W, 18dB = 64x, etc, with a significant risk of overloading and damaging the speaker (tweeter where compensating for hearing loss) unless you limit overall sound level. Also of course for this use good if only similarly hearing impaired people in earshot!
The modern way rather than an analogue graphic equaliser would be using DSP, and there are various products available though I haven’t yet tried myself (my use would be tone controls to correct bad recordings and possible ‘loudness compensation’ if I listen at low levels, also possibly some degree of room correction after whatever acoustic treatment I can do though only cut not boost.
I am 75 and use hearing aids. I have expensive Starkey aids but as I am in the UK, I also have free NHS aids which I only use when I am away so I keep them with my packing stuff (passport, leftover Euros etc.).
My Starkey aids have a range of settings including “music”. This helps but I find that turning them down a notch or 2 compared to normal when listening avoids treble harshness, music then sounds great.
My Phonak NHS aids have a music setting ( the NHS audiologist can set up if not preset). I tried some expensive Starkey ones from a private audiologist when I first had the Phonaks, and didn’t find their music sound quality any better while spurious sounds were mire intrusive. Main benefit seemed to be added bells and whistles that I didn’t need, so not worth their high cost, much of which is not actually the hearing aid, but paying for the audiologist.
I think this is part of the reason that those past a certain age like Naim so much :rofl:
Years ago when I first tried Naim I thought it was a bit screechy and in your face at the top end. Being much older I tried Naim again and it now sounds great.
Have you tried Apple AirPods Pro as I believe those have the ability to tweak the tone response via a slider to boost higher freqs and even create a manual audiogram to tune them.
I’ve got the Pro3 and really impressed with the noise cancellation and sound quality of them.
I regard it as one of those strange things in HiFi. Manufacturers remove functions like tone control or balance control to optimize signal paths. As a consequence, a lot of audiophiles start fiddling with speakers, speaker positioning, speaker cables, inter-connects, power conditioners and what have you to tune the sound of the system to their liking. Maybe these simple tone- and balance controls or a bit of DSP is not such a bad thing and would be much cheaper than all the other fiddling :slight_smile: In the old days tone- and balance controls and a loudness switch for low-level listening were totally normal and many amplifiers had a ‘direct mode’ to bypass all that.
Maybe you should look at the CI-102, which has configurable DSP, for as far as I know.
I also use Sharkey aids - they are the ones I left at home! They are great with music
Thought this was a thread about Linn Space Optimisation. :partying_face:
:popcorn: :popcorn: :popcorn:
Accuphase DG-78 could potentially solve all these problems..
Oh no, Not today Skeptikal :zipper_mouth_face:
To answer the OPs question - YES any Linn Products Ltd DSM streamer includes the advanced settings where Bass and Treble ‘shelf’ adjustment filters are available.
Or, since this is the NAIM forum , how about a CI-102?
Sorry
It was an open goal.
I’ll leave it there. :face_with_open_eyes_and_hand_over_mouth:
Doesn’t have to be hardware based, both Roon and Audirvana have software DSP and Apple Music has sound enhancer that essentially applies a smile curve digital EQ
I am thinking of getting a Macintosh MQ 112. Does anyone have experience of them?
As I understand it the reason for thinking that tone controls are bad is that they can degrade the sound, by for instance introducing phase anomalies amongst other things. Also the general school of thought was that unless designed exceptionally well the sort of boosts or cuts they could make were far too course to be of any great benefit. The other thing is that it can be argued that the tonal characteristics of a system are not fundamental to musical performance. They are just incidental. So risking degradation to alter them is not sensible. If you have a well matched system then best just to accept that recordings will vary wildly in tonal character and leave it at that in my view.
What Pete said
Balance your system then accept the mix it is what it is. :+1:
Pioneer GR-777 this end. Not needed with well recorded material, but a godsend with poorly mastered material.
Any slight loss of sound quality more than offset by being able to actually listen to stuff!
My first amp had tone controls, not cancellable, but my second had them with a bypass switch - best of both worlds. I’ve never had a hifi amp with loudness button, only seen in some other people’s music players - but I didn’t like it as it was a very crude on-off choice, which would only be approximately right at one volume setting - too much baas boost above that, and too little below.
Indeed, people use DSP as graphic equalizers these days… it’s the same thing… just because it has the word ‘digital’ in it the layman assumes it’s better… absolutely not the case necessarily… I guess DSP has the benefit of cheaper quality entry level compared to analogue signal processing… assuming your equalizing a digital source.
Sometimes there are multiple releases of the sane recording available, one well balanced and another far from (e.g with bass cut to enable more to fit on a vinyl disc). If you heard both, would you ge happy to stick with the very poorly balanced one? I wouldn’t, and if a better copy wasn’t available I’d prefer to correct it than not. As I have said in my various posts on the subject, it is simply a question of which effect is worse: the adverse effect on sound quality caused by the tone controls/dsp themselves, or the limitations they are being used to correct it. I have used DSP and haven’t noticed any of the artefacts that purists say it causes, though likely it depends on the degree of correction, and maybe thd soecific DSP implementation.
I once had a JVC JAS22 amp many years ago, before I got my A&R Cambridge A60, which just blew it away in every respect. The JVC had a loudness button, or more accurately a loudness switch, one of those toggle switches which appeared on many Japanese amps back then. It was great fun if you wanted to make your hi-fi system sound like a disco system when you cranked up the volume! Useless for anything else though.
