Do we have to look at the front or the back of the amplifier to identify the effective R/L channel
Looking at the back is of course the other way around of the front
Hope my request is clear
Thanks beforehand
Benoit Lizee
Thanks beforehand
Benoit Lizee
CH1 = LEFT Channel and CH2 = RIGHT Channel
thanks
Connecting one ATC Subwoofer with Nait 5i - 2012 through bi-cabling
banana plug > double cable run Rumour 2 Chord > High connection Subwoofer
Even though the line input is better connected
Is there an incovenient on connceting like this
Thanks beforehand
Better to connect the sub to the lousdspeaker input terminals as connecting two sets to the power amp output stresses it. Also much cheaper as you can use cheap thin cables.
