Ripping individual tracks?
Does anyone know if it’s possible to rip or more accurately re-rip individual tracks to the Uniti Core if they exhibit ripping errors on the first pass…….?
@davidhendon perhaps?
ATB, J
I don’t know of a way to do that. The times I have run into these problems, I have just re-ripped the whole CD. It only takes a couple of minutes.
If there were a reason why you didn’t want to rip the whole CD, for example if you wanted to take the best tracks from two or three damaged discs, then I would suggest rip disc 1, copy it all to another place off your Core. rip disc 2. Which will overwrite the previous rip, save that to your other place and so on. You would need to note which tracks were problematic on each rip. I don’t think you need to worry where you have just a few rip errors in a track. Then put together a best version and copy it back to your Core. There are two options here. You could copy it into the Music folder, although you have to deal with the read only restriction. And then you need to rebuild the database by selecting that option in the app. Or you can copy it into the Downloads folder, having deleted the rip in the Music folder first. Either option leaves you with the best version you have in the Core and being presented by the app as normal. Note though that if you do put it into the Downloads folder then you have to accept that if you want to change the metadata, then you can’t use the app to do it.
Thanks @davidhendon :+1:.
Followed your plan…… sort of :innocent:. As I have dbPowerAmp, re-ripped to Mac (no errors, all checksums good), cleaned up metadata with Mp3Tag, copied to Core and deleted iffy CD rip.
ATB, J
If it’s the clear side of the CD surface that is damaged, some light polish (eg children’s tooth paste) with a very soft cloth, could be used to smooth out the scratches.
After rinsing and drying the disc, retry ripping in the core.
