Hi Spudgun,
With one exception your components are perfectly adequate to achieve highly involving music, so unless one or more of your electronic components is in severe need of a service I think you need to focus your attention on set-up.
So a few questions:
What’s the grey panel under each speaker?
Are those speakers at the other end of the room. Are they wired to anything or just free standing?
What racks are you using?
If that was my room and system, this is what i would do:
- Temporarily remove all room treatments. That’s a lot of bass trapping for a 2-way speaker in a good size room.
- Get the electronics off those thin glass shelves. Naim may have made glass work in their Fraim design, but generally thin, unsupported glass under any electronics sounds horrible…it rings (resonates) energetically, imparts a hard, brittle character to the music and typically has thin bass.
- Consider installing a dedicated electricity consumer unit with dedicated line to the hi-fi room. This is a low cost upgrade that often brings surprising results but does take several weeks to run-in properly
- Check the polarity of all the mains plugs and confirm that the phase going to each component is correct. You need to know what you’re doing with mains, as it’s potentially lethal so don’t check anything if you don’t know how to do it safely with a dedicated phase checker
- Install the speaker spikes directly into the floor. Use the speakers’ standard floor protectors and make sure there’s absolutely no movement. Do this by gently pushing the speakers across the diagonal while feeling for any movement in the spikes. They should be utterly solid.
- Check fuses in all your components and make sure they are the standard Naim supplied pieces. Ask you dealer for a few extras. The same way fuses can improve a system (if you dont mind paying £100s for something that’s broken when it works properly) , bad fuses can also cause considerable deterioration of sound quality, especially loss of vibrancy and lack of involvement.
- Remove the additional speakers if possible
- Personally I would go through an extensive speaker positioning exercise to find the right place to maximise performance. I would also avoid placing speakers with a downward facing reflex port too close to a corner and I would likely end up with the speakers firing across the room, well away from walls and not in such close proximity to bass traps, if traps proved necessary.
