With the level of your system I would be looking at room treatment to bring out it’s potential. If you have a free rein and you get it right I suspect you will forget about any further upgrades.
Take some measurements with REW, if I can do it anyone can!!
Use the measurements as a guide as acoustic treatment is complex and subjective.
Before you do anything read about the subject and there are lots of YT videos to help.
Don’t be in a rush to ditch the door as it may help to control room modes if you can leave it open when you listen.
Also experiment with your speaker and listening position but definitely get your head away from the rear wall.
Good luck.
Definitely fit a dedicated mains. I have done this several times and I actually found that an armoured cable (had to be run externally) was much better than a standard. I’m no expert but I think it has something to do with the way it is earthed???
Love that floor rug!
