searched new forums and did not find any topics. I recently remodeled my room, and purchased my first soundsystem, and now need to treat the room. Wondering what types of room treatments have used, and results.
I’ve contacted GIK Acoustics and even sent them test sound clips of my room using a UMIK-1 microphone. James at GIK made these comments about my room based on test sound clip:
“In addition to previous comments on the bass response, the impulse response shows a LOT of strong reflections, within -20dB of the initial impulse, all the way out past 70ms. This tells me that the room will sound quite uncontrolled and jumbled, with an indistinct soundstage/image. Treating early reflection points on the side walls, ceiling, and rear wall behind you is the first step to improve this.”
So, I need to treat these early reflection points around my room. Particularly, corners and ceiling. Also looking for a floor-standing treatment to put in front of a wet bar with quartz walls. This bar area reflects tremendous amounts of sound in this room, and I need to squash these reflections.
will try to upload pic of my most problematic area. TIA
