It could easily be the PC if both Roon and AudiVana have issues. If you have no issues with the Naim app thats where I would be looking.
Simply put WIFI is not a good way to do this.
As all your kit is in the same room, get a cheap switch and plug them all in via ethernet. You can try this experiment for Ā£20. I am willing to bet it will all work. If it works I can only surmise using a little imagination you could hide the ethernet wires and switch and have yourself a good time.
Longer term, dont use the iMac to serve.
Oddly Roon updated yesterday and it had lost connection to the Novaās RAAT by the evening. A restart and it found it again. Normally itās a pretty solid connection.
Donāt suppose you have a microwave nearby? Ours is close and kills playback when in use.
I bought the Nova also for itās Wirless ability. The Nova is placed in a dedicated place of the library at 1.5m from the ground and getting a cable floating in the air is not an option.
Ps. Why itās not a good idea to get an IMac as a core ?
I asked my internet provider to get the box changed with last generation one, Iāll see if it changes anything.
Well for the sake of a few pounds you can at least establish if the issue is to do with the wifi.
I use a MacBook Pro as Roon Core, and Iām often too lazy to bother connecting a network cable. It runs Roon just fine over WiFi. Plenty of other users run it on various Macs, I donāt honestly think itās a problem.
Well perhaps not but really for best results use a server thats a server, an iMac kind of lends itself to doing lots of other stuff at the same time.
But never the less my suggestion sticks. put a cheap switch in place and hard wire everything, might not even need the switch if the router has enough holes. Its a quick and easy way to discount if wifi is the issue.
