Roon Hidden Albums Help
I wonder if someone can help me with an issue I am experiencing with hidden albums in Roon. The following four albums are hidden; however, I have no recollection of ever hiding them and when I click edit and unhide it does not work.
It is not a huge issue, but an annoying one that is frustrating me!
Tried this in settings?
That has fixed it, thanks. I can now see those albums in my genres and in the albums section.
However, I am still puzzled as to why (a) they are hidden in the first place, and (b) why the ‘unhide’ function when editing the albums does not work…
I can live with it now they are visible, but strange nonetheless.
Could be that the unhide option only works for those manually hidden and those albums were done automatically.. are they duplicates by any chance?
Hi @Deeg
Good spot, this looks like it is the issue. I must have already had a Qobuz version in my library which is higher quality:
However, I find it strange that it would hide BOTH albums from view and not just the duplicate I added by ripping a CD.
Odd indeed, as I don’t use the hide function I’m not sure how it works, if time permits over the weekend I’ll have a play and see if I can repeat the issue.
Thank you, that’s much appreciated. I’m out at the moment, but when I’m home I’ll try removing the Qobuz one from my favourites, turning off the hidden albums setting and then seeing if my ripped version appears :+1:
You were looking at your internal storage in your screenshot so Qobuz albums wouldn’t show up there.
.sjb
