I use Roon Rock running on a NUC. Roon accesses three “sources”: Tidal, Qobuz an my QNAP 219 NAS. Most recently I changed the generic password of the NAS. Expectedly Roon couldn’t access to music files on the NAS anymore. So I thought to go to the Roon properties and just update the credentials over there. Strange enough that does not seem to be possible ! Even “browsing” to my NAS and set up a new connection for Roon, wasn’t possible.
In the end I had to change the NAS password to it’s original to make things work again
You need to disable the current one then add it again as a new network share I am afriaid. It shouldn’t do a full rescan as the paths will be the same.
@CrystalGipsy that’s what I also guessed … stange enough I couldn’t even access the NAS from within Roon. I could only access when setting the pw to it’s original again
