Hi Sean
If I understand right, the Organik Dac Linn designed has a delta-sigma modulator that upsamples the audio data to 1 bit pulse-width modulation stream at 98.304 MHz which in turn is fed to a discrete switched-resistor network which performs the conversion to analogue.
There is a multistage FPGA enabled process of upsampling and noise shaping for PCM files. There appears to be minimal dsp applied to DSD files as they are converted to a pulse-width modulation stream at 98.304 theoretically retaining the timing of the original 1 bit file.
So by getting streaming software like Roon to offload some of the conversion to 1 bit it is likely to change the sound produced due to a) different implementation of conversion algorithms and b) a change to whatever noise shaping is going on in the NG.
Whether that change is better I guess is a matter of taste. Linn must have put a lot of work into the preparation and conversion of PCM files to 1 bit and tune it to their preferred sound signature. I found the change (FPGA v Roon upsampling) to be super subtle - not really sure I could pick it out in a blind lineup. Perhaps a slight softening of some transients. I spend an age a while back comparing DSD recording to PCM recording on my Tascam 3000DA and I eventually could pick which is which so I can hear some of the differences. But I can’t be bothered to spend hours testing this for the NG! I could spin a coin and probably be happy! Good news with Roon is that it is really easy to switch over and on my hardware setup super stable.
My other takeaway Sean is that a Mac M3/M4 sitting on my lap connected via 5GHz wifi (one of my unifi APs is about 4m away in the next room and is hard wired into a different switch) is more than enough server and network oomph to get the file from my NAS and create a perfect bit stream to the NG.
Combine this with the extra network isolation Linn did with the selekt and NG casing/isolation designs, and some common sense networking (dedicated switch for hifi, decoupling switches with utp cable, sensible networking settings etc) and I am getting way better results than my old KDSM streamer. And crucially these factors (server, switch, cabling) seem to have negligible impact on linn’s NG noise shaping now so long as they are setup well in the first place imho. That wasn’t the case before. I got some great help from members here on good simple network setup that was worth its weight in gold all now implemented. Thanks to all who helped.
So I abandoned any messing around with Melco servers, network cables, switches, ferrite chokes as a total waste of my time. All they did was get the old KDSM closer to how the new KDSM now sounds, but imperfectly. Others may have fun playing with these things in their systems and rooms to try and fine tune/override their streamer’s noise shaping but for me in a Linn NG world with my system, it’s not worth any effort whatsoever.
Offloading some of the organic DACs conversion workload to a modern hi powered PC/Mac is relatively easy now with SSD/Multi Core processors/GPU (apple silicon or Nvidia). Personally I prefer not to second guess Linns dsp but if I was unhappy with it at any stage I could easily experiment with different software for conversion and offloading. Did you play with any of the different options and what did you hear?
Good to chat on this as always. Jon.
