Hi all
Do any of you use the volume leveling function. I seem to be struggling from one track being loud to the next quite. Thought of giving this ago but is probably detrimental to sound quality.
Hi all
Hi
I have tried it a few times and have not been happy ( I’ve used the Automatic setting )
Cant put my finger on it but things seem a bit less involving
(It does involve a lot more processing / conversion its seems )
I switch off as much DSP by default
Yes I use it almost daily when I’m background listening and exploring Roon Radio. Technically it is slightly detrimental to SQ but I turn it off for critical listening. It’s annoying when I forget to disable it however…
Agreed.
I do not use it for critical listening.
