Hi there.
I have NSC222
After the latest upgrade of Naim software,
I cannot see the sampling rate info of the played track in Naim App when I use Roon Ready.
I can see the sampling rate info when I use Tidal Connect.
I could see sampling rate of Roon ready before latest upgrade of Naim.
Could anyone help
Me ?
Can any one answer?
How can I see sampling rate in focal and Naim spp when play via roon ?
I do see the sampling rate in focal app if I play via tidal connect
Why do you need to use the Naim app if using Roon?
What’s wrong with the Roon control app?
I would like to make sure that there is no change that Naim is doing to the sampling rates as it was before in in tidal connect
Naim aren’t responsible for the bit rate?
Martin
Have you contacted Naim support? I would guess they would be the only ones here who may be able to give you the information you need.
Well, that seems odd. In the Naim app there are two display option for the current track. One displays the track playing together with the playlist. If you toggle the icon top left the other display option will show the bit rate.
How do I contact Naim support?
I thought that Naim support team are checking community threads
No they don’t.
Yes it is odd. I can see bit rate if I play via tidal connect or directly flac track in my library.
I do not see bit rate if I play via roon ready
No, the forum is mostly for Naim user discussion, although many issues can be answered here by the membership.
If you would like some assistance from Naim then details can be found here on the website;
Naim can be contacted by email on support@naimaudio.com
