Does anyone have a Samsung 2018 or 2019 UHD TV, that they use with Sky Q?
I would like to get the Q9 Flagship 2018 model, but there is a 19 page thread on the Sky Forum stating that there is an issue when using the Samsung Q9 with the Sky Q box. Apparently when the Sky Q Box is put into ‘Standby’, then woken up, the Samsung TV comes back with Sky Q box not found. This then requires the Sky box to be unplugged and reset.
There appears to be a communication issue between the Samsung ‘One Connect Box’ and the Sky Q box…As per usual, Sky and Samsung are blaming each other for the glitch.
Has anyone had this issue? Thanks
