I have a set of mk1 SBLs updated to mk2 that I have owned for many years.
I purchased them second hand from someone who had used them active, so the crossovers were never mounted.
I have ever since just had the crossovers hanging loose at the back of the cabinets - I think I was told this was preferable over mounting them. I noticed recently that the cabinets are actually pilot drilled for mounting the crossovers - should I look into mounting them or just leave them as is?
That’s good to know I got some 2nd hand PAXOs with my SBLs and always wondered if they should have been mounted though I never did or had the screws etc to fix them.
On another note do PAXOs need servicing any more than an internal crossover and if so can they be?
