I have both sbl & sl2 speakers and was told ? that the bass/midrange units were the same, however the sl2’s units seem to have a ‘dope’ finish am I correct ? can this finish be applied retrospectively ?
Therefore two different types of SBLs. On the MK1 the driver is “pressed”, the MK2 has a cast chassis and this one should be the same as an SL2 I believe.
Not the same afaik, Sl2 150 RMS, SBL 100 RMS?
You can still get bits from Naim but running low get in quick.
