I’ve used Craig Deoxit screen cleaner on my LED TV screen for years but need to renew the supplied microfibre towel cleaning cloth and wondered what product might be a suitable replacement ?
A quick internet search brings up a whole plethora of products but I’m not sure if a general microfibre cloth will be suitable for a TV screen so any advice would be greatly appreciated, size wise I’m looking for something about 30cm square.
I use mom screen cleaning stuff for TV and monitors. Comes with what looks like a regular microfibre cloth. I have plenty anyway and just wash every now and again. No problems here.
Plus a micro fibre cloth.
Do test on an inconspicuous area first!
Mark
I used to use a screen spray/wet wipe but just ended up trying to clear the smear - like cleaning windows on a sunny day.
Now I just use a damp paper towel to clean off fly poo - yes, that’s what those tiny black dots are ! Then a lint free silky microfibre cloth.
If it’s a Samung Q range don’t use anything you will end up rubbing off the antiglare coating and making the screen worse.
