Hello,
Would anyone have listed the different screw tightening (Nm) on SBL?
Thank you
Hello,
Thank you
Are you talking about torque on the bass driver bolts? I believe it’s 3.6Nm but an email to Naim will confirm.
Stu
The bolts on the mid bass drivers should be torqued to 3.6Nm
Hi Stu, Hi Richard,
I thank you, meanwhile I had similar information.
