The NAC32.5, bought locally along with a NAP250 (ironically this unserviced NAP250 is the youngest of the 4 I own), has just come back from Class A so I’ve started setting up the ‘second’ system on the kitchen floor to ‘warm’ it up a bit.
As you can see it is a hodge-podge in terms of vintage consisting of a NAC32.5, 2off Hicaps, a NAXO 2-4 and the one NAP250. I’ll be ‘borrowing’ a NAP250 from the main system and dragging the Sara’s down from upstairs over the weekend.
In and around the rugby I’ve now set-up and tested the system and can report it works - yippee.
The bad news relates to the NAP250 I’ve ‘borrowed’ from the main system. I deliberately targeted the one of the three that has been tripping.
The case was notably warmer than the case of the other two, bordering on hot. It seems pretty obvious that something is not right as all it is doing is sitting there idling so should be running lukewarm at best.
Have sent an EM to Darran at Class A but does anybody on here have any experience of NAP250’s running hot?
I’ll be putting the unserviced NAP250 back in to the main system after the Scotland - England game. Unfortunately the Welsh only managed to finish second in Dublin
I want to put together a second system to go into my garden office (about 13 x 12 feet) with wired internet. I am thinking of a Naim streaming pre-amp and ATC active speakers. Recommendations, please. I want to buy used equipment to keep cost down
The one NAP250 was still getting hotter than the other two when it went back into the main system but I think I have now solved the ‘problem’ in that I believe it was down to the plugs on the end of the cable.
They are as far as I know the ‘correct’ Linn item but the ‘prongs’ had become ‘over compressed’ on some of them making them a loose fit in the sockets in either the amplifier or the speaker.
I have spread them all out using a jewellers’ screwdriver so that they are all a firm fit and the problem does seem to have gone away.
I have now also split the NAP250’s and Supercaps from the NAC52, SNAXO etc. so they each have their own racks and used 140mm spacers all around to allow more air to access things as well.
I must admit that I probably need to re-do it as I put the ‘power’ bits on the left and then when it came time to connect things discovered that the Burndy’s were a bit stretched…
