Thanks for this advice… makes sense…
Also, if the speakers don’t lift off very easily you should twist them off while keeping them level. In extreme cases you can rip a bit of veneer off if you are too heavy handed.
Does blu tack have a running in phase, then with a window of optimum facilitating performance before a new service intervention ??
Asking for a friend
I remember using a speaker that sounded more altogether in my room with those flat square sponge pads used for kitchen general cleaning rolled up within the reflex tube.
Started moist and great- but when they dried upthings started to sound off.
And if they don’t readily respond to being twisted, you can cut the Blu Tack with dental floss, working inwards from each corner with a sawing action.
