I tested this when I had the ND5 XS2 on loan: I ran my humble Primare NP5 through the ND5 XS2 and heard no difference at all. Overall, the ND5 just did not manage to get me emotionally involved in the music. I think it’s down to my personal preference for how music should sound, for example I prefer the SN1 to the SN3 even though I agree that the SN3 is cleaner and does a better job at detail and soundstage.
When I got my nDAC, I was blown away by how engaging the music became. Switching from the Primare to the Rivo+ gave another jump, especially in how realistic instruments and voices sound, it’s on par with my Rega P6 (but different). I would love to test the Rivo+ through the ND5 XS2 dac, I just think the Naim special sauce is more in the dac than the streaming part. So to me it does not make much sense to get an ND5 XS2 if you only use the streaming part.
The digital transport matters a lot to ensure that the nDAC is fed with a clean digital stream that is as free from timing issues (jitter), data loss etc. Nothing downstream can compensate for data lost or with errors introduced before the digital to analogue conversion takes place. I’d be wary about using a cheaper alternative transport.
I should have clarified, I was talking about a Primare NP5, I have no love for cheap Chinese stuff. My point is not that the streaming part of the ND5 XS2 is bad (it’s obviously not) but that a decent streaming transport can be just as good if you are only using the streaming part of the ND5. For the price difference you could get an XPS on your nDAC.
I added the Ndac to an ND5XS2 I already owned which I assume most people do. It’s no slouch and I am more than happy with it as a transport. I also have the XPSDR and the combination of the three is perfection to my ears.
When the nDAC was originally released I owned one and used it with a rotel CD transport. Compared to the CDS2 I also owned, it was clear (night and day) that the CDS2 was far better. So I sold the nDac.
About 4 years ago I bought second hand ndac and paired it with a Primare NP5/ifi power supply/VDH toslink (cost under £700) and it sounds superb. It’s refined and detailed, with the detail being delicate as opposed to in your face.
So, a relatively inexpensive good quality modern streaming bridge can sound excellent with the nDAc. Spending more should sound even better, although at the end of the day personal taste and synergy play a part.
If it’s the volumio rivo plus, then I can believe you. It’s not really a cheap transport, at 1300 euros.
I thought it was more something like raspberry pi, costing 100 euros. If this later do better than the Nd5xs2 transport, the Naim could be considered as very poor I feel.
Hi! The question is, what are the sonic benefits adding ndac without the XPS DR? Most people mention the significant improvement they achieve by adding the external power supply, but what kind of sonic performance can you expect without it?
Thank for your responce, from what has been said, I understand that there may still be a small degree of influence.
However, I still have the following concern, and I will try to clarify it before making a purchase: is there any risk of a firmware conflict between the two devices, or is there a clear guideline from Naim on this?
From the discussion above, I understand that firmware version 3.13 improves the performance of the ND5 XS2. I have also learned that the nDAC, as a separate device, has its own firmware updates, with version 4.11.8 being the latest.
When we update the ND5 XS2 to version 3.13, should I assume that only the streaming section is updated, or does the update also affect the firmware responsible for digital signal processing and the ND5 XS2’s internal DAC?
When I connect an external DAC that receives its own firmware updates, can I be certain—or at least reasonably confident—that version 3.13 will not conflict with version 4.11.8, and that this combination is therefore acceptable under Naim’s guidelines?
For me it cleaned everything up and gave it a warmth, adding the XPS put space between instruments, added depth and added realism. FWIW I could happily live with every step without changing anything. I’m glad I made the changes all the same.
Adding the nDAC will improve the sound because, in simple terms, you are replacing the DAC in the ND5SX2 with a better DAC which also has it’s own box and power supply circuitry away from the digital transport part of the ND5SX2. If you then add a power supply to the nDAC such as an XPS DR this takes the power supply away into a seperate box from the DAC audio circuitry in the nDAC. The power supply in the XPS DR is also a higher spec than what is in the nDAC. Generally with Naim, you get better sound quality the more boxes you have, although there are exceptions to that. It’s a similar story if you were to get a Supernait 2 at some point. It can be upgraded by adding a power supply such as a HICAP DR.
A firmware update for the ND5XS2 affects the streaming section and the internal DAC section. The firmware versions of the streamer and an external DAC (like an nDAC) are not interdependent. So, no worries there.
How does the firmware affect the DAC portion of Naim streamers? I’ve read that the DSP process isn’t affected and has remained the same despite firmware upgrades.
The DSP can certainly be updated as part of a standard firmware update. How often Naim actually make changes to it, as opposed to the streaming board, I wouldn’t know. I guess you’d need to ask someone from Naim.
For as far as I know, the firmware includes settings / software for the internal DAC section. But that part of the firmware was not changed for a long time. That is how I understood it.
OePhi Immanence Power cables made a (very) dramatic difference in my system. As did a move from Tidal to Qobuz. FWIW! Every system is dependent on so many factors as everyone here has eluded to… The room, speaker placement (sometimes down to mm’s)… but my biggest upgrades have been to power once I had the equipment I wanted. The PC especially allowed that equipment to be its best.
