Servicing needed?
Have had 2nd hand Supernait for around 6 years now. Think it’s not sounding quite as good as it should, so considering sending to Naim for a service when stuff hoes into storage for a house move. Can’t find anything about this on Naim website- is it a wise devision??
Yes. Servicing is recommended and reports after servicing always note an improvement.
Either book in through your dealer or speak to Darren of Class A Audio, as they are a bit quicker and cheaper.
DG…
Class A do not service the original Supernait as it has DAC & software.
Its only done at Naim HQ, via a dealer
I had m7 2008 SN serviced in 2022
Delivered to dealer 20-July and collected 25-Aug.
Job Sheet
Reported faults – Logo dull, slow Start Up
Faults confirmed – Logo bleed & failing BO cap
Replaced reservoir caps
BO cap
Fitted jitter mod & updated to 01-04/01.03
£399 + £20 P&P
The FAQ gives a bit more info here. Sadly the Connections article from the old website is no longer up. Hopefully it will be reinstated at some point on the new one:
