Hello, I’m using my nd5xs2 ‘digital out’ with a Chord Qutest as external DAC. I only stream music (Qobuz) and internet radio, both IN the Naim app. Now, in the (app) settings of the nd5xs2 I can chose between PCM and Native settings for digital out (BNC) to my Qutest DAC. Which is the ideal/technically advised setting for this kind of use/streaming, regardless of sonic preferences/differences (which there are)?
I can’t find any (for me comprehendible) advice for the ‘right’ setting to be used.
Maybe they are both technically OK and then I can just chose what’s my (sonic) preference. But they sound so different that I assume one of these two is superior to the other.
Thanks in advance!
I’d go with native and the dac will do dsd or pcm depending on what’s being sent to to it from the Nd5xs2
I’ve a similar setup and ‘Native’ works fine for me. Now you just need a MScaler…
