Something I found out a couple of months ago bit still consider worthwhile mentioning.
Like many other brands my speakers, a set PMC 25.23, have screw in spikes. With a nut to secure them. Checking my setup I found the spikes and nuts to be loose, shaky and rattling. Needles to say that tightening the nuts with a spanner did improve sound quality.
Small check, easy fix.
