I have a MK1
Sent them an email and they confirmed it was compared against ND5XS streaming board in this case
272 works great with tidal has so since hard wired great but if kit have mine with 555ps and hard to get better for price range for me anyway
I had the Wiim Pro wired to my SuperUniti for the exact same purpose. And Tidal was worse. Not day and night, but the SU-streamed Tidal sounded better. Same for locally stored music btw.
It takes a really good streaming transport to consistently beat even the 1st gen Naim streaming board.
The Primare NP5 is definitely better than the WiiM, but even still isnât definitively better than Naimâs 1st gen streaming board: in some ways better, in some ways not as good (and these results are consistent from other reviews describing the characteristics of the NP5). Whether you consider the Naim board or the NP5 to be better will be a matter of preference.
I used an NP5 into an NDX Gen 1 (as a DAC).
Sounded really good - smoother and a little more detail than the bare NDX, but perhaps lost some rhythmic drive (comparing like for like UPnP).
I also had an MCRU power supply on the NP5. Great bit of kit that can be hidden away out of sight!
Iâm really unclear as to why streamers used as transports into Naim DACs (or Naim streamer digital inputs). I may have got this completely wrong but doesnât the streamer bit just provide the DAC with a stream of bits and clock data? Doesnt the DAC then apply DSP before converting to analogue? Surely the only parts of the process that can affect SQ are the DSP and analogue output stage. If thatâs the case then different streaming transports should all sound the same and the Naim effect is just in the DAC. Iâm probably completely wrong so feel free to give me a slap.
Edit: Maybe if the streamer and DAC share the same clock, thatâs what makes the difference?
If only it were that simpleâŚ
Itâs at least partly streaming functionality - the gen 1 Naim streamers donât support all the streaming platforms there are nowadays so using a Primare NP5, for example, gives an early Naim streamer a new lease of life.
I might not have understood your question though. If itâs SQ related, rather than functionality, then itâs a can of worms and might be worth a search for old threads on the topic. Please apply a preventative cold flannel to your forehead beforehand.
While the 272 suffers from a lack of functionality with todayâs streaming platforms it is still, IMO, an excellent sounding streaming preamp. Particularly with an external power supply (and I am using a Teddy xps - not even close to a 555ps) . For half the cost of the upgrade to a 222, there are many more options for adding a streamer. For example the Lumen U2 mini with the linear power supply upgrade. It also has a bnc digital out that connects nicely to the 272. There are others too that I havenât listened to. I am leaning towards an Innuos Zen mini mk 3 so I can have the added benefit of ripping and streaming my cd collection (but I havenât listened to it yet). But I wonât base my decision on how the 272 sounds with the Wiim pro. We are still discussing the 272 because it punches well above its price point. I am not sure if the 222 does.
I have had my 272 for a couple of years now and I absoloutly love it, it has never had an issue playing Tidal.
All I can tell you is that I did not use the Wiimâs DAC, I had it wired via Toslink into the SU. So what I compared is the Wiim streaming âsignalâ going into the SUâs DAC vs. the SUâs streaming âsignalâ into the very same DAC. And the result was convincing - for the SU (which I think has the same streaming board as the 272).
I have my Unitilite in a box for this reason.
I do not have a 272. However, I am one of many here who has tried ( in blind tests with 2 or 3 sets of disbelieving ears) to compare differently sourced streams of bits into the same DAC and amplification.
We satisfied ourselves that there was a consistent, easily audible and consistent difference between different sources. Thus, a stream of bits from my Mac sounded a lot less good than that from a Core into my NDX2, but that still lost out to my old CDS2 - until we put the external PS on the NDX2, at which point none of us could pick consistently between stream, rip and CD.
As with the claims when I was young that CD (irrespective of the details) offered âPerfect Sound Foreverâ, it turns out that ears are quite discerning and reality is a bit more complicated than some suggest.
Given all that, and the 272 âs reputation as a jolly good pre-amp (esp if it has a good PS), Iâd suggest giving 1 or 2 streaming-source options a listen and seeing what your ears say. Donât be surprised if nothing cheaper than a Naim ND5XS2 or equivalent can maintain your interest after the 272.
same here the Wiim Mini Pro through toslink into my Chord Mscaler/Dave sounds really good. I am not going to spend more on a streamer.
I have the Wiim volume set on fixed, not variable, that may account for some folks not enjoying the wiim digital output maybe?
Comparative conclusions (relative to 272), from an informal âmeta studyâ of some available streamers:
Allo one (inc âSignatureâ)
Overall: not as good - general agreement
Detail: less detail, less focus, less good timing.
Notably good VFM
Wiim Pro
Overall: Not that far off, but still not as good - strong majority opinion
Detail: less detail, less good timing.
Notably good VFM
IFi Zen stream
Overall: Not that far off, but still not as good - general majority opinion
Primare NP5
Overall: Similar performance overall, but different characteristics - general agreement
Detail: more detail, better focus, less good timing.
Notably good VFM
Auralic Aeries G1
Overall: general improvement in several areas - majority opinion
Detail: Opinions are more varied here
IFi Zen neo
Overall: general improvement in most areas - majority opinion
Auralic Aeries G2 & G3
Nice, when you say âmeta studyâ do you basically mean a literature review/collation of othersâ thoughts about the listed options?
Exactly so (hence the âinformalâ descriptor!)
Canât understand people saying they have a problem with Tidal and their 272 using Ethernet! I have had one with 555 PS and love it, never had a Tidal problem but i do have a 3rd part streamer which I use for its other functions and that sounds the best through the 272 DAC Via copper rather than optical against its internal DAC
If meeting a tight budget a 272 plus 3rd part streamer ( Blue sound Node 2i is my current) is a great option particularly if you can get a 555 PS later on.
Still thinking about upgrading 272
