it arrived today and it is wonderful. Sound is pure joy.
My other attached kit is not Naim.
Is it possible to change input source with the remote control? Does the remote control do any more than turn off the display and adjust and mute volume and balance?
never owned one, but it is the narcom5 remote, to get it to control the unit, I believe you only have to push the button for pre (at the bottom. It will then control more. pushing any number from 1 to 6 will then change inputs (each one has an assigned # corresponding to the buttons on the front of the 5si with the far left input as 1 and the far right as 6 (I’m assuming it is like most of their pre-amps with 6 inputs. All of this is o n-line from naim and you should look at it. ENJOY
