But what do I do with my cd’s
Can I get them onto the amp
Try Brian and Trevors, all one word.
You can rip your CDs on a computer and store them on a NAS if you have a bit of time and patience. Then you will need either a DAC or a network streamer to play them.
If that all sounds like too much hassle you can buy a dedicated ripper/music store. My choice would be an Innuos Zen Mini. Stick the CD in it, and 5 minutes later it’s stored and ready to play. It can also store music downloads, and stream from online services. It has a basic DAC built in, so you can connect it directly to an amp, although you may want to buy a separate DAC for better sound quality.
You can also use the Zen as network storage if you buy a streamer. Then you can hide it out of the way and just use a network cable to connect it to your router.
