Hi all, my system is cds3/xps2/252/300, all powerlined and in fraim
Have been using SL IC and speaker cable, so next step is consider to upgrade the original xlr cable to SL xlr cable for my 300 (full loom), is this a noticeable upgrade and worth?
Or other would prefer upgrade the xps2 to 555ps, instead of SL xlr?
My main concern is the sound will be changed more hifi and not as release as my current set up, so that is not belongs to upgrade but presentation change.
My favor music is pop, pop rock and some jazz, so the main concern is the mid range (meaty/natural vocal sound), so that is the reason that i don’t want to upgrade to DR version (DR sounds more hifi and thinner than non DR)
Would appreciate for your suggestion/opinion on the above two upgrade options.
Best Jerry. Your statement about DR vs non DR is completely the opposite to, what I have found. Am curious as to what experience re DR, that makes you state this? Peter
My experience with DR upgrades on HiCap2 and 250-2 are exactly the opposite. Bass became more refined and the mids were more richly-textured and musical after the upgrade, without losing any resolution/definition (and that improved too, actually).
@Best_jerry brought in a 300 in to my system couple of years ago and then got 300 DR, IMO the DR takes the 300 on to another level completly, my source is LP12 and NDX and has improved both in detail and musciality and for me is certainly not a thinner sound, in fact for me the oposite
if not that I would look at 555 on the CDS3 and on XLR either SL or Cord
hi!I changed those for witch hat cables and really liked the effect, haven t tried SL,but based on the price alone, they should be better than what i have.For a while i had only one pair of new cables(active sistem),so i d swap them between bmr and bass amps.Gotta say, difference was pretty audible.Regular cables don t have any shielding, i think;so they sound harsher.
Noted the above DR comments.
Would like to go back to my question, what about the presentation difference in between the original xlr and SL xlr for 300? Is this upgrade obvious and worth?
Thanks again for your input!
I’ve recently swapped the stock cables with SL DIN-XLRs on my 300DR. The SL cables are a noticeable upgrade, not exactly jaw dropping, but they give a more refined sound - top end is clearer with a better defined, tauter bass.
If you already have the SL interconnect then it’s worth upgrading the DIN-XLRs. I’d recommend buying preloved (as I did) or ex demo. They are overpriced at £3K for a new set.
I have SL din to XLRs. As well as giving more detail they are more natural and give a much greater insight into the musical performance. They do sound funny at first and take a good while to sound right. I’ve found a great synergy between them and the speaker cables. In my view DR makes more difference than the SL cables and they the two work extraordinarily well together, which is perhaps to be expected as they both come from the Statement project.
