I have super lumina full loom plus naca5 for speakers. I tried chord music etc but always preferred the “live” replay of naim SL in context of ND555dr/552dr/300dr.
Question - i am going to homedemo a non-naim integrated amp against my trusty 552dr/300dr and want to keep a SL interconnect, so only change is the amp.
Should I use SL din to rca, or SL rca to rca. I will have to purchase the IC for the homedemo so appreciate any advice
I arranged to get the vitus homedemo and then covid hit. I read in dunc’s thread that a) clearly best in class a and b) it runs warm in that mode. Also they seem to recommend not to keep it on in class a at all times. So not sure vitus will be a practical choice for us.
The family uses the system a lot so i need an amp that can be turned on all the time and be fit and forget. That seems to be the case w aavik - and its another local/danish option for me. As i use nd555 as single source I was not hooked on paying for dac and riaa in the u380. However they just released a pure integrated amp u580 that should be cheaper and better (w/o riaa and dac). So will give that a try.
