SL speaker cable - take off little Naim box?
Does someone know if it is possible to temporarily take off the little Naim (ferrit core?) boxes at the end of the cable?
I am considering getting the cables through preinstalled in-wall tubes with a smaller diameter.
Thx.
Yes, you just need a small Allen key. I removed the speaker end so that I could pass the cable through a conduit behind the fireplace. It’s really easy. There is a resistor at the amplifier end, which may make it more fragile, hence removing the box at the speaker end.
Thank you, hungryhalibut. Much appreciated.
