I got a small electric shock when I switched off my LP12 turntable last night. I think I also got a a small shock when I switched on the Nait amp a few says ago. The turntable is gounded to the amp.
All hi-fi now unplugged.
Is this is a sign that I should get a new 6 way (6 plug) extension lead?
Or should I tidy up the cables at the back of the hi-fi rack?
Touch the back of your hand first. Hurts let’s than the tip of your finger. Also you can earth yourself on the faucet in the kitchen if you have metal pipework.
If you only get a shock when touching your system I’d suggest having a PAT test just to make sure all earthing is good, and nothing is live. Better to be safe than sorry.
Many years ago I used to get a tingly shock if I touched something metal that was connected to my PC system. It went on for many years.
In 2019 I had the house rewired and it was found that the earth in the socket that all my PC was plugged into had a bad earth connection.
After the rewiring I got no more shocks.
So whilst it could be just a build up of static, it may be there’s a problem with the mains where it’s all plugged in.
One thing you could try - if you have an RCD plug something like this -
I get static when I wear my trainers in the room,
Now I just touch the radiator before touching my kit,
Even if I’m static free,
it’s a ritual for me now🤣
If it is a build up of static, try this trick. Learned when working in an office years ago, with a large number of metal filing cabinets. Before touching the cabinets, after walking across synthetic carpet, we would stamp a foot - worked every time. Those who forgot, soon learnt to remember! edit - good job today is not April fools day!
I suffer from static electricity now and again with my LP12, I notice it more now that I have moved to a more modern house. The worst bit is that I touch the deck tentatively for some time after a shock, and once I relax again because I haven’t had one for a while, it zaps me again.
Update: I have just used a laptop computer for first time in a few weeks. I went to switch it off and unplug it: I got a wee electric shock (less tjam from the LP12)
I think I also got a small electric from the toaster 4 days ago.
I’ve taken the dehumidifier out of the living room.
The situation you describe with your car and static was responsible for an explosion at a gas station when I was young. Cold weather, people wearing wool, start the fuel flow from the pump, then huddle in the car. When the hose clicks off they get out, go to remove the hose from the fuel tank and ZAP. Fumes and a spark.
An experience not limited to hifi at this time of year.
Our cats are changing to summer coats.
This has the side effect of them having lots of loose hair in amongst the floof. So when you touch them you often get an electric shock. They’re like mini Van Den Graaf bundles.
Can range from a mild tingle to a bolt which elicits sweary words from us and a loud Meow from them.
While it’s happening get in to the habit of using your knuckle to ground yourself as it doesn’t hurt as much there. Drinking more fluid will also help. A friend of mine had to take tablets to help him many years back. We used to charge ourselves up and then touch use our knuckles to touch a workmates ear. Childish, but it kept us entertained and alert!
Indeed, a colleague of mine was asked to troubleshoot some very sensitive medical equipment in the Far East. Flew from Frankfurt to Singapore and back. Turned out the operator in question was wearing…
