Does anybody have an explanation and/or solution to the following: my SN3 switches itself pretty often from Streamer (NDX ‘1’) output to CD (CD 5SI). System automation ( System automation allows the NDX to integrate the control of Naim hi-fi components) is enabled. It happens once or twice a week. Of course I can disable system automation for a week and see what will happen, but if this is a known bug maybe somebody can share some more about this issue
Hi Misha
I think it could be because your preamp input setting is not correct. If you look on the app at Input Settings you’ll see various Preamp inputs (on mine they are numbered 1 to 6). If you switch and try different preamps, one will be correct. Sorry not sure which one, but easy to try. Hopefully that works.
Hie all, I don’t have a CDP & my NDX is connected to the CD input on my Supernait.
I don’t have this problem,
I also have a NAT-05 FM Tuner linked to System Auto
The NDX System Auto settings I use are as follows, maybe something to help & check against yours.
All the settings are in the NDX front panel display, to change these you use the remote control
-> go to -> System Automation
Pre-Amp > Enabled
Pre CD > No
Pre-Tuner > Yes (with no FM tuner your set this to no or disabled)
Pre HDD > Disabled
Pre AV > Disabled
Pre Aux1 > Disabled
Pre Aux2 > Disabled
DAC > No
Streamer Audio > Pre CD
CD Player > No
My app input setting are as the picture, but the important stuff is in the Front Panel Display
Okay, so I disabled all accept the streamer audio and put it on input 3, because Stream is input nr 3 on my SN and also has the streamer on that input. Let’s see what will happen now
That did not work, pre amp must be enabled, otherwise it will not work at all. I checked the Naim manual for system automation, but it will not explain or guide you through alll the possible settings… Maybe there is something more detailed available?
Hi Misha
Hopefully Mike has helped solve your problem. I never owned one of the old streamers so assumed the set up may be the same as my second generation streamer.
Good luck.
