Soon we will be converting the loft, which provides an opportunity to build a second system. We haven’t even started with that building work but I still fancied playing around with a Supernait 2 – so I bought one, and it got delivered today.
Unlike my previous XS2, the SN2 pops through the speakers when switching inputs or muting the amp. Is this normal, or something I need to worry about? These pops are similar to switching on a 250DR – maybe not quite as intensive, sounds a bit like two short mini-pops compared to the 250DR.
The sn 3 I am currently using have the same very marked sounds when muting the amp. If I were new to Naim this would really have made me question the amp.
Claus
I had the Qutest, TT2 connected via the cd connection but it was DIn rather than rca. Is it possible to test it with a Din cable to see if it does the same.
Ah ok - IIRC the Chord DAC doesn’t provide a signal to mains earth connection. It might be worth trying connecting the SN2 earth post to your mains earth - this may cure the popping issue.
Initially, the speakers “hummed” because of earthing arrangement with the Hugo 2. When I “switched on” the earth on my Allo Nirvana power supply for Allo’s USBridge Signature the hum disappeared. So I thought all fine now – but maybe not quite… I guess I’ll need to make up a cable to earth the SN, rather than earthing through the power supply.
Revising my previous statement; faintest of clicks only noticeable when you wind up the volume. There’s memory for you, convinced myself there was something more audible. My av amp definitely clicks and clunks.
