MaxiMe
September 17, 2021, 6:13pm
1
My Supernait 2 has lost the left channel, but only on AV bypass. The AV input in normal mode is fine as are the other inputs.
I suspect it needs some TLC from Salisbury and I’ll talk to my dealer in the morning.
In the meantime does anyone have any clever ideas?
It’s not the source, I’ve been able to eliminate that as an issue.
james_n
September 17, 2021, 6:28pm
2
I’d power it off (including the Hicap if you use one) and leave it off for 5 mins before powering it back up. Worth also trying to reset to factory default settings.
If you still have a problem then it sounds like it will need some TLC
Buryfc
September 17, 2021, 6:59pm
3
My 552 did exactly this and it was a faulty relay.
MaxiMe
September 17, 2021, 7:24pm
4
Seems the most likely, everything else is fine.
system
Closed
November 16, 2021, 7:24pm
5
