Thanks I will.
And… please… report back… Lets learn from this…!!
I’ll hook up my Uniti 2 to it tomorrow to see if there are any noise issues there.
OK thanks will give that a try.
See here -
I haven’t tried this yet. Interestingly when I connected the Uniti 2, the buzz disappears completely but reappears if I disconnect It.
I take it you mean you have the Project TT and the Uniti 2 both connected to the SN3 ?
If so, with them all connected, change the ground switch from chassis to floating on the Uniti 2. Does the buzz come back ?
Yes with the TT also connected.
Yes it does when on floating but it’s much a quieter buzz.
That makes sense. So just use the system with the Uniti 2 connected and the ground switch set to chassis. If you don’t have the Uniti 2 in the system (or a Naim streamer), then you’ll need the extra ground wire on the SN3.
I think you mentioned previously you were going to use the Uniti 2 for now before changing to a dedicated Naim steamer ?
Yes but not for a while. The vinyl sound is on another level now which what I was I after and it drives my P3ESRs a lot better too. Even the Uniti 2 is sounding better.
Thanks for the advice.
Good stuff. Enjoy your new amp
Progress - and more understanding. Welcome to the madness of Turntables…
