Would anyone know the cost of replacement fascia for an SN3, I have somehow managed to ding one of the corners, it’s a small mark and have touched it up so it’s not that noticeable, but just thinking if it’s not an excessive cost to replace I might get it done.
Your dealer or Naim would be best positioned to answer this, surely?
I can’t recall the correct amount, but had a similar question a couple of years back regarding a NAP200 facia … I was a bit unpleasantly suprised by the high amount.
i would think its a major strip down of the amp and a big lump of anodised ally is not going to be cheap!
