A simple question. Should the locking ring for the Snaic 4 between a Hicap and supernait be locked or loose?
I would lock them. If they loosened and there was a poor connection or even disconnection, the squeal could take out a speaker drive unit - tweeter in particular. Loosening the looking rings on interconnects though is OK.
As it’s a power supply I would lock.
You don’t want to risk accidentally unplugging and ending up with a flickering power supply until you can get to the off button.
thanx.
locking rings Snaic 5 between supernait and stageline also be locked?
Yes, keep SNAIC rings locked to prevent costly accidents.
