Snaic Black Directionality
Good evening.
I have tò connect this latest arrival.
I would like to know,if the green label"in the photo"should be positioned on the NAC or Hi-cap side.
Thank you
As I understand it the end with the label goes closest to the source signal. Between a Nac and Hicap this is the NAC.
Correct. Collar to signal source end.
Many thanks!
Try it the other way around and see if you can hear a difference!
