Snaps 4 pin
Hi can you help I have a early version snaps 4 pin can I use it to power a nac 102 pre/amp the amp I am using is a cb nap 140
You can. You’ll need to have the link plugs fitted in the NAC102. Use a SNAIC4. Then Take preamp signal from the SNAPS to the NAP140.
