hi everyone, can a snaxo 2-4 be converted to a 2-4-2 ? thanks
AFAIK, no it can’t as the board layout, fascia and casework are all different.
It can be re wired so that you can use different amps like the newer version can, as i had mine wired that it could run both ways, the 2 connections on the back that are used for 135’s i had re wired so that i could use say one amp to run bass and another to run the treble
