Here’s the connection diagram for a SNAXO 2-4 (I assume it’s a SNAXO 2-4 here?) to a pair of NAP250s. It’ll be the same for a pair of NAP110s. However, you should use a pair of Naim DIN4 active leads instead of SNAIC4s as the SNAICs can make the SNAXO unstable. It will sound better with the active leads.
So, was it not until the black series that you could have one stereo amp on the HF and one stereo amp on the LF. My 110s sound slightly different so that would be my preference. Although I’ve got a couple of CB 140s being serviced so perhaps they will be closer to one another.
Some have re-wired older NAXOs and SNAXOs for this orientation but then, unless you carefully re-label everything it can get very confusing, with sometimes calamitous results.
My biggest unknown is if the SNAXO 242 will be better served by the Supercap-DR than the 282 with a pair of olive HICAPs but that will require a dedicated Burndy for the SNAXO 242 to compare which is probably something I’d be unable to demo.
Thanks, that’s interesting, and something I’ve often wondered about. I would assume that the SNAXO 242 might be able to take better advantage of the benefits of the Supercap DR compared to the NAC 282, though initial plans were getting it as a stepping stone to the NAC 252.
I was pretty confident in the end so went for it and all is working well
Most stress I’ve ever had with HiFi I think but got there in the end.
Sounding good but not really much better than my best pair of passive Kan 1s. Better bass control with the improved out of band damping. Musically, not quite as good I think although one 110 is slightly better than the other which isn’t ideal. Plus the mass of cabling is a total mess. Mind you, I’m told they have not been played in nearly 20 years so perhaps I’m being premature.
NAXO and Olive HICAP also need a Naim service and the NAXO needs tweaking from SBL to Kan settings but don’t know how much difference that will make.
Proper Linn converted ones, shipped directly to Naim back in the day…
Fantastic experiment - let us know how you get on. Active Kan are on my bucket list to try in place of my active SL2 (also have passive Kan, IBL and SBL)
