Hi all - if a Snaxo 242 was factory set for SBLs would it need resetting to run with SL-2s or are the settings the same? Thanks
It’s the same crossover points although the internal level settings might need a little (very slight) tweak.
Many thanks both.
AFAIK, the crossover frequencies are set within hardware on the various (S)NAXO’s, with only the levels being adjustable via internal pots.
[I imagine the frequencies are set by SOT Resistors (Select on Test) - or whatever Naim may call them.]
